TD 6, low oil pressure
Jack W Ford
04-25-2007 20:46:17
I have a 1950 TD6 that runs very well, but when it warms up the oil pressure drops way off. I would like to fix this before any other damage is done. I'm not sure where to begin. Any advise would be greatly appreciated!
Thanks
RAB
04-25-2007 22:57:25
 Re: TD 6, low oil pressure in reply to Jack W Ford, 04-25-2007 20:46:17
Oil quality/grade, oil pump, bearings, pressure relief valve. Any and all. After oil, start with pressure relief, if it is an external serviceable item, as seat is likely worn. If it is bearings, it may need crank work as well.
Regards, RAB
