IHC TD340 steering and pivot brake adjustment
kenny/md
04-26-2007 20:15:37
Hi, can someone tell me how to adjust the steering and pivot brakes on my TD340. I can get it to turn, but I have to pull REAL hard on the levers. I'm sure its an adjustment problem, I had the cover off, and the steering linings looked good. I bought a specifications manual, but it doesn't tell me how to adjust the brakes. If someone could email me procedure I would appreciate it. Thanks for any help, Kenny
t340crawler
04-27-2007 18:44:05
 Re: IHC TD340 steering and pivot brake adjustmen in reply to kenny/md, 04-26-2007 20:15:37
Kenny,
I sent you an email with the adjustment page
Take a look at my webpage for pictures of the steering clutch linings also(maint link)
Joe
http://t340crawler.googlepages.com/home
Charlie
04-27-2007 15:02:20
As the other post says, loosen the locknut to let you make the adjustment. The only thing I would add is that you have to do the adjustment with the steering lever pulled all the way back. Otherwise it feels as though there"s no adjustment left. The right adjustment will be determined by a couple of inches of free play in the lever.
icebite1
04-27-2007 09:51:10
Kenny, there is an old post that may help,i dont know if this is what you need but worth a look, search "t340 has power one side only" on this site. Charlie
hectorgemme
04-27-2007 03:22:42
if the td340 is like tdc5 you should find under the seat a rod screw adjustement with a jam nut you have to loose the jam nut and adjusted your stering cluch break.
