Case 450B Loader to Dozer?
Mark Rinaldi
04-27-2007 18:49:35
Does anyone know if it is possible to convert a 450B track loader to a 6 way Dover blade? I know the 450's came with both but I have not saw a dozer up close to see if it is possible? If so where could on get a dozer harness and blade and is it an easy retrofit or a major undertaking?
Thanks in advance.
Case450
04-28-2007 02:49:05
 Re: Case 450B Loader to Dozer? in reply to Mark Rinaldi, 04-27-2007 18:49:35
Perhaps you can install a 4 in 1 bucket for more versatility. I think Sean has one on his machine and he says its greater then sliced bread! I have a crawler loader too and find them to be much more versatile then a standard dozer. You have a lil more crafty to get cleaner grades when finishing but nothing you cant handle.
I have never done a conversion like you are talking about but off the top of my head I would imagine it to be a fairly substantial undertaking. Plumbing your lines wouldnt be too difficult but moutning a harness to the frame and remvoing the bucket arms and assembly. Lot of fabrication there.
Whatever you do, best of luck.
marlowe
04-28-2007 02:34:26
first WHY? it will cost more to do this then find a dozer and you can do the same things with a loader and more then you can with a dozer. try loading a truck with a dozer. you can cut a ditch with a loader they work better to push stumps and i like them better to level dirt with then a dozer
