690B swing gearbox lube
j schlosser
04-28-2007 17:31:13
On my 690B excavator, there is a swing gearbox below the hydraulic (swing) motor. The manual calls for 80-90W gear oil in this gearbox. However, due to the age of the machine, I think the seal in this gearbox is leaking out the 80-90W oil, and it drains down to the main swing gear (which is supposed to run in texclad grease.) The swing works fine. Would it work to use a heavier lube in the swing gearbox that is not as liquid as the 80-90W, and would not leak past the seal as quickly?
Roy Suomi
04-29-2007 18:43:03
 Re: 690B swing gearbox lube in reply to j schlosser, 04-28-2007 17:31:13
Sure , anything is better than nothing....Someday you will have to rebuild it or pedal it.. I;ve made a slurry of grease and gearlube with a power paint stirrer for the "57 Gallion grader at work....
