Case 480C transmission
CR
04-29-2007 14:24:13
I have a Case 480C backhoe with a powershuttle transmission. The forward drive is very weak in all but first gear, it can't make it up a small grade. Is the problem in the torque convertor, powershuttle or both ? Any suggestions to troubleshoot the problem? Thanks,
CR
Riderdiablo
07-02-2007 20:28:59
 Re: Case 480C transmission in reply to CR, 04-29-2007 14:24:13
Still giving you problems? I may have an answer
JFoshee
04-30-2007 21:44:33
I can't tell you what to check without looking at a manual, which I don't have access to anymore, but it sounds like the shuttle. I worked for Case for 7 years and many times when a machine came in that didn't have power in forward, but was fine in reverse it was the shuttle. The forward disc get worn from loading and driving while reverse seldom has any "load" on it. If you do determine it is the shuttle the remanufactured shuttle is your best bet. You get a practically new shuttle vs. rebuilding your old one and you still got alot of your old parts.
CR
05-01-2007 04:12:35
 Re: Case 480C transmission in reply to JFoshee, 04-30-2007 21:44:33
Thanks Jfoshee, Can the shuttle be removed without pulling the engine?
JFoshee
05-01-2007 22:51:45
 Re: Case 480C transmission in reply to CR, 05-01-2007 04:12:35
Yes it can be removed without pulling the engine, but you will need a jack or some type of lifting device cause it is HEAVY. At least to heavy to man handle. Take your front bucket and stabilizers and lift your machine as high as it will go. Block up under the rear axle and front axle so the machine won't fall on you. This gives you much needed working room. If you don't have any blocks to put under the machine it is possible to do this with it on the ground. IF you don't have any blocks PLEASE don't try this method. Also, instead of a jack it might be possible to run a come-a-long down from the top to let it down with. It's been a while I forget.
JFoshee
04-29-2007 23:26:25
How does it do in reverse?
CR
04-30-2007 03:18:45
 Re: Case 480C transmission in reply to JFoshee, 04-29-2007 23:26:25
Reverse is OK. I checked the fluid and pickup filter they are OK.
Thanks,
CR
Case450
04-29-2007 16:28:16
Fluid levels? Filters?
