JD440 Crawler clutch
Alan Goetz
04-29-2007 17:40:24
today i started the 440 for the first time this year, but when i pushed the clutch in to put it in gear the gears just kept turning and i couldn't get it in gear. i turned the engine off put it in gear and then restarted it while holding the clutch in and it was ok. i ran it back and forth and was able to shift ok, but if i left the clutch out then pushed it back in i couldn't get it in gear. what would be the repair for this problem and what caused it? Thanks in advance for help
Alan Goetz
04-30-2007 18:08:27
 Re: JD440 Crawler clutch in reply to Alan Goetz, 04-29-2007 17:40:24
ok, i appreciate the info. Thank You
Lee Bradley
04-30-2007 13:18:11
Sounds like you have a sticky clutch but not stuck or you would not have been able to start it in gear without it moving. Just go ahead run it for a few days to polish up the pressure plate and flywheel surfaces.
Lavoy
04-30-2007 07:38:10
The clutch disc is stuck to the flywheel, it is caused by moisture and rust, although I had one that was caused by mice living in the bell housing. You might get it to break loose by pushing some dirt or pulling a heavy load while holding the clutch in. Otherwise, you will need to split it and take the clutch out.
Lavoy
