650G John Deere Dozer turning issues
D Haye
04-29-2007 19:30:42
This dozer does not turn to left like it should without first putting slight pressure on the right steer pedal. Could this be some kind of steering valve sticking?
gemsvc
05-01-2007 08:46:43
 Re: 650G John Deere Dozer turning issues in reply to D Haye, 04-29-2007 19:30:42
You need to adjust the steering controls. The adjustments are made at the steering valve using two hydraulic gauges, do not adjust the linkage! Once the linkage has been tinkered with it's difficult to get it back right. You will need the manual for this, there are two sets of measurements- the serial # will tell you which measurements to use.
Roy Suomi
04-30-2007 16:55:35
Look the linkages over for sticking , rusty conditions..I've seen a lot of these machines with rusted linkages causing the brake band to drag and eventually wear out ..
