cat grader 140h gear not shifting
rajesh raju
04-30-2007 00:01:57
could anyone pls reply me as the grader's gear dosent shift any further from 4th...changed the burned clutches, couldnt find any visible damages on gear parts
Bob/Ont
04-30-2007 14:12:49
 Re: cat grader 140h gear not shifting in reply to rajesh raju, 04-30-2007 00:01:57
Rajah, I think you have a hyd problem in the trans that took out the clutches. See if your local dealer will make you a copy of the trans test sheet and then get some gauges and test it. You will find the problem.
Later Bob
