TD 9 Charging system
Butch 1 cow
05-01-2007 18:41:45
I'm working on a TD 9 for an older guy and he has the battery on Pos. ground. It's a gas- diesel and I can't get the charging system to work. Are these tractors Neg or Pos ground? Thanks for any Help!
AJK
05-01-2007 23:56:35
 Re: TD 9 Charging system in reply to Butch 1 cow, 05-01-2007 18:41:45
You may need to polarize the generator,connect it up and momentarily use a jumper wire between the Bat terminal and the Arm terminal on the regulator,you just tip the wire to the two terminals for a millisecond,you need to have the battery connected.
Good Luck
AJ
DWF
05-01-2007 19:40:17
The older TD-9's like you're working on are positve ground. The 92 series and up are negative ground.
DWF
Butch 1 cow
05-01-2007 19:56:36
 Re: TD 9 Charging system in reply to DWF, 05-01-2007 19:40:17
Ok Thank You!
