TD-9 idlers and rollers.
Eddie Olive
05-05-2007 21:01:53
I am restoring a 1954 TD-9, I was wondering where I might purchase some new grease seals for the front idlers, I also need some new bulbs to fit original type headlights. In my manual it calls for 140 wt. oil for the idlers and rollers, is this a must or can you use a good grade grease. Thanks Eddie Olive.
OneWelder
05-16-2007 17:39:35
 Re: TD-9 idlers and rollers. in reply to Eddie Olive, 05-05-2007 21:01:53
When I was younger I did a fair amount of track bottom work. I believe your machine came through with "Rotary seals" very expensive,and would leak at the first sign of bearing wear.
At that time you could go to a "cat style" replacement seal made by BERCO for the 92 series Int.
Can't remember for sure but maybe same as early td8.
stopped doing this work in early eighties, I could be wrong
Davis In SC
05-06-2007 20:23:19
After seeing the price on the seals.. Perhaps it is worth going to a bearing house, to get a match up ??? As a rule, seals and bearings are cheap at the bearing houses.. I once needed a bearing, the dealer quoted 45 dollars, but it was not in stock.. I went down the road and got one for 4 dollars...
Eddie Olive
05-06-2007 18:58:44
I appreceiate the information on the front seals I will give them a call. The number on my headlight bulbs is 2320 Tungsol 32210 and has what looks like 8 volts. I would like to find them in 12 volts if possible. Thanks Eddie Olive
Bob Plumadore
05-06-2007 07:10:14
NAPA should have the bulbs, yes you need 140 oil, grease does not circulate. I believe 85-140 is what you will find easier.
Bob Plumadore
05-06-2007 16:00:16
 Re: TD-9 idlers and rollers. in reply to Bob Plumadore, 05-06-2007 07:10:14
what are the numbers on your bulbs?
Eddie Olive
05-06-2007 14:18:44
I have contacted NAPA and they were not able to find the right bulbs. I figured circulation was probably the reason for using 140 wt. oil opposed to grease. If anyone knows where I might find some new seals for the front idlers, would be a great help. Thanks Eddie Olive
Jim Presley
05-06-2007 18:15:40
 Re: TD-9 idlers and rollers. in reply to Eddie Olive, 05-06-2007 14:18:44
I just bought a set of front idler seals for my TD-9 91 series from F.P. Smith in Fairfield Calif. Pricy, $80 each.
Link
(800) 55-TRACTOR
Jim P
Eddie Olive
05-06-2007 19:22:29
 Re: TD-9 idlers and rollers. in reply to Jim Presley, 05-06-2007 18:15:40
I appreceiate information on idler seals I will give them a call. The numbers on my headlight bulbs are #2320 Tungsol 322102. Thanks Eddie Olive
