TORK SPEC FOR INT 500 4 CYL DIESEL DOZER
ROSCO50
05-09-2007 00:13:19
I HAVE A INTERNATIONAL 1969 500C DOZER WITH A 4 CLY DIESEL DOES ANYBODY KNOW THE TORK SPEC THE ROD BOLTS AND HEAD BOLTS AND THE MAIN BOLTS
ben brown
05-10-2007 16:00:19
 Re: TORK SPEC FOR INT 500 4 CYL DIESEL DOZER in reply to ROSCO50, 05-09-2007 00:13:19
head 75-80 ft lbs rod 40-45 ft lbs main bearing pitch bolt it is a bolt thred larger then shank. place bolt 80-85 shank and tread dia. are the same this torque game from bookon b 414 2444 2424 all with bd 154 engine and that should be wht you have as the earlt 500 serie used the 4 cly.
ben brown
05-11-2007 18:25:34
 Re: TORK SPEC FOR INT 500 4 CYL DIESEL DOZER in reply to ben brown, 05-10-2007 16:00:19
if you have pitch bolts 75-80 ft lbs.pitch bolts have a smaller shank running from head to thread then the treads are a larger diamenter. place bolts shank same diamenter from head to end of tread on thies bolts 80-85 ft lbs. i would probley tork. to 80 ft for eather style
ROSCO50
05-11-2007 22:00:52
 Re: TORK SPEC FOR INT 500 4 CYL DIESEL DOZER in reply to ben brown, 05-11-2007 18:25:34
OK THANKS
ROSCO50
05-10-2007 21:08:17
OK THANKS BUT YOU LOST ME ON THE SHANK WHAT DO YOU MEAN place bolt 80-85 shank and tread dia
Milton
05-10-2007 12:57:20
There was a 3 cylinders motor (German) and a 4 cylinders motor (Britian) in that 500C crawler.
Milton
Milton
05-10-2007 12:57:13
Milton
CHinNY
05-09-2007 04:45:27
A 500C would have a 3 cylinder in it
ROSCO50
05-09-2007 21:39:52
 Re: TORK SPEC FOR INT 500 4 CYL DIESEL DOZER in reply to CHinNY, 05-09-2007 04:45:27
SORRY I WAS TOLD IT WAS A 500C IM REBUILDING THE MOTOR AND I NEED THE TORQ SPECS
