AJK
05-12-2007 15:49:00
Re: leaking fuel pump in reply to Case450, 05-11-2007 18:31:09
You need to be handy but not a genius if your loader has a Perkins engine with a CAV rotary pump,there are two o'ring on each of the spindles that go through the top cover,your first move should be to obtain the four o'rings and the gasket that goes between the cover and the pump,the top cover must be removed in order to remove the spindles as they fit from the inside out,to remove the cover first disconnect the controls,undo the nut that holds the lever to the throttle spindle noting how it was fitted,undo the two dome nuts that retain the cover,lift the cover up about an inch and no more,push the throttle spindle in through the cover and take the cover away,now have a good look at where the spring that I have marked green in the picture that I've posted at the link below and note which hole both ends are attached to in the spindle and goverenor plate,it is most importand that it goes back in the same place,replace the two rings on the throttle spindle, take the lever from the stop spindle and note it position,put new rings on it and put it back in the cover,use washing up liquid to lube the o'rings,clean the cover and glue the new gasket to it as it is very narrow and won't stay in place while you fit it but the glue does the trick,put the cover over the pump and push the throttle spindle through its hole and put the cover in its place making sure that the spring is connected to the same position and that the peg on the stop spindle fits into the stop control bar,tighten down the cover,connect up the controls job done. AJ
