jd loader stops pulling
ray porter
05-12-2007 17:45:52
i have a john deere 450C loader. when it's cold it has good pushing power but after about two hours it starts to slip and will not pull itself. Next day it works fine for another two hours Can anyone tell me the problem and will it harm it to continue these two hour sessons
Roy Suomi
05-13-2007 06:37:00
 Re: jd loader stops pulling in reply to ray porter, 05-12-2007 17:45:52
It's certainly not going to do it any good to continue to run it that way..Do the HLR adjustments I have posted in the YT archives..If you still aren't able to get it to act right , you might be in line to get an HLR overhaul...Pressure has everything to do with that transmission working correctly.... Do the clutch pedal "free-play" adjustment.. HLR pressure / speed of shift adjust- ment.. Whats happening there is the pressure is dropping off as the oil heats up..If the transmission is adjusted up to snuff , it won't generate excessive heat to keep the oil within it's viscosity limits.. Finally there might be an internal problem all the adjusting won't cure...Good Luck
