JD 350 steering
CR
05-13-2007 10:53:40
I worked all day with my JD 350 crawler with no problems. The next morning the left side steering was out. I adjusted to steering clutch per the manual, but no luck. The left track continues to move no matter how hard you pull the left lever. Right side works perfectly. Any suggestions.
Thanks, CR
troy21
05-15-2007 21:52:29
 Re: JD 350 steering in reply to CR, 05-13-2007 10:53:40
to see if its oil on the brak or the clutches not relesing u can pull both levers and see if the dozer stops moving..then u will know its somthing n the brake or clutches
original possum
05-13-2007 18:29:36
If the brake doesn't load up the engine when you pull hard then it is probably oil on the brake bands. The clutch can be disengaging, but you have no brake. If it does load the engine then your clutch is not disengaging.
KSTractor
05-13-2007 17:25:28
If its a 350C the steering clutches are hydraulic and the lever opens a valve to dump the hyd. pressure to disengage the clutch.
CR
05-13-2007 19:04:41
 Re: JD 350 steering in reply to KSTractor, 05-13-2007 17:25:28
It's a 350 with mechanical steering no hydraulics.
CR
Vapet
05-14-2007 16:14:31
 Re: JD 350 steering in reply to CR, 05-13-2007 19:04:41
Take off the cover over the clutch and take a look and see what is going on when you pull the lever.
