caterpillar diesel 50 injector lines
jfh
05-16-2007 16:34:54
thanks again for the advice so far. i was wondering what yall thoughts were of making them out of galvanized steel brake line . i can get a roll from 25 foot to 100 foot , just wondered if it would work . i would put a straight compression sleeve on it simular to the original line and then flare it ? any help thanks in advance
Old Magnet
05-16-2007 21:57:16
 Re: caterpillar diesel 50 injector lines in reply to jfh, 05-16-2007 16:34:54
Good advice again. Those old flat seat injectors had breaking pressures as high as 1600 psi. See your local fuel injection shop.
george md
05-16-2007 21:23:14
NO, don't do it , inj lines are very thick wall
tubing. They are thick enough that to form bends, you will need to make a set of dies with the proper diameter groove and the radius needed. I
made 2 sets of different radius to bend a set for
a cockshut tractor . You can buy straight tubing
from a fuel shop with one end installed , bend it , then cut to length, other end is a hi pressure swedge-lock fitting . If you don't use
the dies , you will deform the tubing and make
a restriction for the fuel
george
