JD 350 steering brake
CR
05-21-2007 13:50:56
The left steering lever on my JD 350 crawler appears linked to the brake pedal. When I step on the brake pedal it locks the left steer lever. I freed up the yoke and rod going to the steering cluthch housing, but the lever still sticks.
Any ideas?
Thanks,
CR
jdemaris
05-23-2007 11:29:27
 Re: JD 350 steering brake in reply to CR, 05-21-2007 13:50:56
You've got a shaft that frozen in a yoke - it's a very common problem with 350s. You can try heating it, and at the same time - hold your foot down - HARD - on the brake pedal, and at the same time, try to force the steering lever back and forth.
CR
05-23-2007 14:04:49
 Re: JD 350 steering brake in reply to jdemaris, 05-23-2007 11:29:27
Thank you, for your input. Where is it frozen? At the brake pedal linkage or in the steering clutch housing? CR
jdemaris
05-23-2007 17:48:31
 Re: JD 350 steering brake in reply to CR, 05-23-2007 14:04:49
Inside the steering-clutch housing. It is the right on top, easy to see and heat with a torch. A shaft passes through the inside of a cast-iron yoke (one is for steering, one for brake). They get rusted together - thus your problem.
CR
05-23-2007 18:24:06
 Re: JD 350 steering brake in reply to jdemaris, 05-23-2007 17:48:31
Thanks for all your help.
CR
original possum
05-21-2007 19:53:10
Yep. The clutch and brake share a shaft in the final drive housing. Pull the covers of your left and right housings and you'll see how the left moves differently and where it needs freeing and lubrication.
