D8 15A series G
DGH
05-22-2007 18:12:21
I am looking at a later series G 15A D8. The pony is missing. What other machines used the same pony engine? What were the common problems with this model. What are the operating pro's and con's? Any advice appreciated.
DGH
05-24-2007 09:26:47
 Re: D8 15A series G in reply to DGH, 05-22-2007 18:12:21
Thanks for all the information. I will check it out further. Did the 15A have wet steering clutches?
Old Magnet
05-24-2007 20:54:46
 Re: D8 15A series G in reply to DGH, 05-24-2007 09:26:47
Steering clutches are the dry type.
DGH
05-24-2007 21:20:12
 Re: D8 15A series G in reply to Old Magnet, 05-24-2007 20:54:46
Thank-you Old Magnet!
hector gemme
05-23-2007 02:11:48
I HAVE A REBUILT 15 A PONEY AND MORE PONEY USE PARTS.
Old Magnet
05-22-2007 18:53:39
The 15A is not a power shift. It uses a torgue converter drive to a standard type transmission. It was a little odd in that it uses the diesel fuel for the torque converter fluid.....so you don't want to run low or out of fuel. The pony motor shared use with other D8's and D7's of that era. These were the ones (depending on serial number) that had the shared lube system with the main engine of which most were converted back to separate systems. They are a pretty good tractor, either the 14A or 15A. Seeing that you do not have a pony, direct start would be a good choice.
NC Wayne
05-23-2007 16:29:47
 Re: D8 15A series G in reply to Old Magnet, 05-22-2007 18:53:39
I knew that...don"t know why I said Powershift... musta had one of those DUH moments...
Old Magnet
05-23-2007 17:25:36
 Re: D8 15A series G in reply to NC Wayne, 05-23-2007 16:29:47
We all have some of those moments.LOL....more as ya get older.
NCWayne
05-22-2007 18:30:13
Since you don"t have the pony to start with....and unless you"ve "just gotta have" the pony, convert the old girl to electric start. I worked on the pony engine on a 14A D8 a few years back that is identical to yours except it"s straight drive instead of "powershift". True the pony has certain advantages but all I can say about it is it"s EXPENSIVE to work on.... The main thing I saw on the machine I was dealing with was that if your not running it every day or keeping it stored under cover the mag tends to draw moisture and doesn"t want to work, and that really hits the wallet. Used or aftermarket parts are getting hard to find for it (the pony that is) and those that are still available through CAT, again, are EXPENSIVE.... Give Bill down at Iron Peddlers a call and see if he can locate an electric start setup for your machine. Cost and performance wise you"ll come out alot better off in the long run.
