Jd 40 series crawler
ralph leonard
05-30-2007 15:38:04
need info on drive train clutch assembly, clutch worked fine last season, parked and now no clutch at all, pedal flops back and forth?
Roy Suomi
05-30-2007 19:09:21
 Re: Jd 40 series crawler in reply to ralph leonard, 05-30-2007 15:38:04
If the linkage outside the clutch housing is OK and any pins aren't missing..You might have to pull the engine to see what happened to the clutch or linkage inside the clutch housing..
ralph leonard
06-01-2007 07:24:56
 Re: Jd 40 series crawler in reply to Roy Suomi, 05-30-2007 19:09:21
not sure about linkage, seems to be on same rod from the brake pedal, pins? sure need help to understand what I am looking for. also it might be a 420 crawler, it has front loader instead of blade, and five roller trac. do you know the differance, and i can email pics, thanks alot
