JD 310A, Hyraulic return line keeps bursting
Edward1990
06-08-2007 12:14:41
There is a 1" return line by the hydraulic filter under the tractor next to the right rear wheel that has all of a sudden began to blow hoses. It is hose clamped on and the metal tubes it connects to have raised rings around them so I assume it is designed to be this way. Any ideas what could be causing it to blow. It will blow reltivly quickly and it doesn't matter whwt the tractor is dsoing. Thanks
original possum
06-19-2007 11:01:53
 Re: JD 310A, Hyraulic return line keeps bursting in reply to Edward1990, 06-08-2007 12:14:41
Make sure the supply and return hoses are not swapped at the quick-connects.
AJK
06-08-2007 13:21:29
The hydraulic filter may be blocked
AJ
