JD450 B track adjuster
Gus
06-11-2007 18:22:21
Looks like a ring,maybe a snap ring that probably holds the seal in has slid out. These were new adjusters about two years ago. I"m going to try to drive it back in but looking for any tips available so I don"t screw it up. Thanks, Gus.
Roy Suomi
06-11-2007 19:42:44
 Re: JD450 B track adjuster in reply to Gus, 06-11-2007 18:22:21
There is no ring that holds the dirt seal in place..If there's some sort of ring "dingling" around , thats the metal part of the seal.. It's rusted apart or broken apart from the rubber of the seal..It's a force fit similar to a wheel seal on a trailer drum..
Gus
06-12-2007 02:59:08
 Re: JD450 B track adjuster in reply to Roy Suomi, 06-11-2007 19:42:44
Thanks Roy. Makes sense, but it sure doesn't look like that. I'll clean the dirt/grease off and have a better look. That means the whole thing needs to be pulled apart. Both sides were replaced by AIS and always leak down faster than I think they should. I want to upgrade machines but I got too much money into this now to justify it.
