Cat d4
mark
01-01-2002 17:07:35
just brought home my first dozer,cant seam to find serial #,found plate on left rear engine with
patent #'s only.what numbers should i be looking for and how many?
Pat/WV
06-12-2003 11:45:24
 Re: cat d4 in reply to mark, 01-01-2002 17:07:35
the number on the left side of the engin is the tracto serial #. look on the back of the housing. there should be a tag bolted on to one of the inspection plates
paul adams
04-29-2002 12:21:37
mark
go to back end casing on tractor, there you should find i.d. number stamped into casing, depending upon age and model of tractor.
regards
paul
Celeriac
01-02-2002 14:16:30
Mark, check out the antique Cat board. I'm sure the guys there can help you out.
Celeriac
01-02-2002 14:15:26
