quick connects for JD 350c
Mike Martino
06-12-2007 06:12:36
Looking to buy new quick connects for the backhoe on a 81 jd 350c crawler loader backhoe. Was wondering if anybody knew were i could get them for a decent price. I almost fell over when i called nortrax for a price.
Thanks again
Mike
mark ace
06-16-2007 21:07:50
 Re: quick connects for JD 350c in reply to Mike Martino, 06-12-2007 06:12:36
try aeroquip couplers through grainger. i have these on mine & they work great! about $50
Mike Martino
06-13-2007 04:42:56
Thanks
$84.00 for the female and $40.00 for male seemed high. Do you know what psi is needed for them.
Thanks
Mike
Bob/Ont
06-13-2007 06:56:34
 Re: quick connects for JD 350c in reply to Mike Martino, 06-13-2007 04:42:56
What ever your working pressure is,3000 PSI maybe. Two things to watch for if you have hyd problems on a system useing Quick connectors.
One is wear from the locking balls in the groove and the other is the clip holding the spring inside getting out of place.
Either one can result in them not opening up fully when connected together.
Almost blew up a pump I was testing once from a spring clip getting loose. The spring didn't have enough force to hold the opposite connector valve open, flow was deadended, it was a piston pump and protected it's self or I would have been wearing some of it.
Later Bob
Bob/Ont
06-12-2007 10:45:43
Mike pay the price up front, buy Domestic Made QUALITY. If they wear or come apart inside they cause you Big Problem$ down the road.
Later Bob
