JD 310A backhoe hard start
Ketsoc
06-12-2007 13:08:32
I have a John Deere 310A backhoe which would not start over the winter. I have drained the lines, replaced the fuel filter, cleaned the injector lines and bled the lines. Can anyone suggest a good location for a service manual? I guess I need to learn how to run a compression test.
Jonathan in MA
06-12-2007 18:39:29
 Re: JD 310A backhoe hard start in reply to Ketsoc, 06-12-2007 13:08:32
Does it start hard or does it not start at all ? When you are cranking it to start , does it emit smoke from the exhaust ? Low compression would smell like raw fuel.
Ketsoc
06-15-2007 09:09:16
 Re: JD 310A backhoe hard start in reply to Jonathan in MA, 06-12-2007 18:39:29
Thanks for the reply. At first it was black smoke, then finally white smoke. I finally got it started but I used more starting fluid than I wanted or probably should have. When it was warmed up, it started good in the past.
Jonathan in MA
06-15-2007 12:41:48
 Re: JD 310A backhoe hard start in reply to Ketsoc, 06-15-2007 09:09:16
I don't really understand what that means... but here's something that may help
***** Cranks over and emits whitish/grey fuel smelling smoke but does not fire --- that is low compression
***** Cranks over but doesnt smoke at all or very small amount and does not fire -- thats a fuel delivery problem -- clogged tank screen, transfer pump thats NFG , clogged filter, injection pump problem etc...
