How do they do it?
Poppin' Johnny
01-01-2002 17:30:26
Howdy folks. I was just pondering...
How do crawlers get not just more traction, but more pulling power than the same tractor but on rubber? For example, a John Deere 430 utility or something like that won't pull the 4 bottom plow the crawler would. Why is this? Is the transmission different?
charles ethridge
01-01-2002 17:51:05
 Re: How do they do it? in reply to Poppin' Johnny, 01-01-2002 17:30:26
hello popping johnny, i have not took the time yet to figure out the tranmission ratios, but i am going to guess that if you put a 430 on about 24" wheels ,which would be about the same as on a 440 crawler then you would have maybe the same amount of power and used the same gears, the crawler would have more power because there would be a greater amount of reduction in forward movement per each turn of the engine. good question!
TonyK
01-01-2002 18:05:57
 Re: Re: How do they do it? in reply to charles ethridge, 01-01-2002 17:51:05
Hi Charles.
There are a few things to consider here when we talk about traction.
The crawler weighs more. The gear reduction is lower. But most of all the crawler does not have a differental. Both tracks are locked and are driving. The crawler also has more surface area to obtain traction from. Just look at what is in contact with the ground at any one time as compared to a rubber tire tractor. Of course should you want to go any where quick the crawler is just as they say, Just a crawl'n along.
Since my 40C has been together I have entered it in 2 antique tractor pulls. The 40 with the blade weighs in at 4,850 pounds and with me on it just under 5000 lbs. Depending on the track conditions when pulling the sled, put the crawler in low, bring the govener to the top and wait. If the track is good you will stall the engine when the weight moves up the sled. If the track is loose you will dig 2 small ditches. Oh and you know who wins in the catagory, the crawler of course. There are 40 and 50 HP machines there spinning their wheels against an 18 hp crawler.
Bye for now,
TonyK.
charles ethridge
01-02-2002 17:15:48
 Re: Re: Re: How do they do it? in reply to TonyK, 01-01-2002 18:05:57
you are right tony, the pulling power is one of the main reasons this type of machine was maded and like you said , you aint going no where fast, but will get there, i have had these things stuck before and that is no fun, but a wheel tractor normaly will get stuck before a crawler
