distributor spring set for case 580b gas tractor
danielknutsen
06-13-2007 12:29:04
just overhauled my case 580b-ck need to get springs for the centirfugal advance.the case # is a24778.also the motor is a g159b/2776659.i would like to know how to attach the inner&outer governor speed springs located on the governor control rod.one more request how many of these gas models were produced?
CENTAUR
06-13-2007 16:27:48
 Re: distributor spring set for case 580b gas tractor in reply to danielknutsen, 06-13-2007 12:29:04
It might help if you could give the forum the BRAND of DISTRIBUTOR and MODEL on the riveted TAG.Is it a DELCO or a AUTOLITE/PRESTOLITE or?I am not in a position to help.Others may have access to what you need.Some distributors have fixed posts and others are ajustable.CENTAUR
danknutsen
06-14-2007 07:59:45
 Re: distributor spring set for case 580b gas tractor in reply to CENTAUR, 06-13-2007 16:27:48
thanks for the info. The tag on the distributor reads prestolite IBT-4403-a-8G.the case parts book list the distributor as an Auto-Lite #IBT-4403-A
