CASE CK BACKHOE PIN AND BUSHING
AmeriKen
06-16-2007 18:29:01
I'm in the midst of replacing lower pin and bushing on the swing tower of my CASE CK backhoe. As best I can determine it is a model 32 backhoe. Can the pin/bolt, nut, washers, and ball bushing be acquired as a kit or do each part have to be ordered? Here are the part numbers individually:
Pin: D37451
NUT: 25-1324 (1-1/2" - 12 NF)
SPACERS: D26991
BALL PIVOT BUSHING: D23601
Are these parts available from aftermarket dealers?
Old Magnet
06-18-2007 07:38:30
 Re: CASE CK BACKHOE PIN AND BUSHING in reply to AmeriKen, 06-16-2007 18:29:01
AmeriKen,
The D37451 pin is a part number for the Model #33 hoe. You will probably have to get those parts from Case
jdemaris,
Part of the problem with that lower tower pivot is the D30760 pin on the #32 is not long enough and eats half way through the upper support. If you change to the D37451 pin and special D36476 washer used on the #33 hoe you get full purchase at the upper support. I'd be curious to hear how you repaired the hogged out holes....weld & align bore...bush...or??
jdemaris
06-18-2007 06:47:41
About 3/4 of all the pins and bushing are available aftermarket - but a few must come from Case. And those will cost twice what they are worth since Cases knows you cannot get them elsewhere. I just put all new ones in my 32 hoe. Biggest problem was that big self-centering bearing. With mine, the bore in the casting was worn out and egg shaped.
