cat 955 h final drive sprocket
tony baggette
06-19-2007 17:31:13
Hey fella's
I have broken a sprocket....i have all the parts i need, just need to find someone or a place to rent the puller and press to get the thing off...
any help is greatly appreciated, by the way I am in va.
mightyvalk
06-23-2007 15:13:48
 Re: cat 955 h final drive sprocket in reply to tony baggette, 06-19-2007 17:31:13
I went throught the exact same thing. I had to pull the sprocket case and final. Then have it pressed apart then had someone come out and press it back on. Where are you located? By the way don't use the recommended CAT sealant for the gasket it sucks. Mine seaps I should have just used permatex.
Bob Plumadore
06-19-2007 18:49:44
I usually pull the Final Drive and sprocked off the tractor and carry it to one of my lolcal undercarriage shops and let them press it apart and back togeather.
