J/D 450C TRACK LOADER OIL IN WATER
S/C BOB
06-23-2007 09:19:57
My 450 is getting oil in the water and it`s also overheating too.I haven`t really done any checking yet. Just wanted to ask and hopfully get pointed in the right direction...Any help will be appreciated....Bobby
jdemaris
06-23-2007 10:21:42
 Re: J/D 450C TRACK LOADER OIL IN WATER in reply to S/C BOB, 06-23-2007 09:19:57
That's kind of uncommon. It usually is the other way around with water in the oil. If you're sure, your problem is probably the engine-oil cooler leaking into the coolant. Usually, where ever a coolant passage is near an oil passage - the coolant has more pressure and therefore travels passes into the oil.
bcPA
06-26-2007 06:18:30
 Re: J/D 450C TRACK LOADER OIL IN WATER in reply to jdemaris, 06-23-2007 10:21:42
If you have a 7 to 10 pound radiator cap and are running 30 or 40 pound of oil pressure then the oil would end up in the radiator. Now when you have a coolant leak into the hollow voids of a engine like into the crankcase the coolant pressure is greater than the air pressure in the crankcase. A leaking or cracked injector sleeve or the oil cooler seem to be the main suspects in this case. If this machine is run I would loosen the radiator cap when it is shut down so the 7 lb of coolant pressure is not pushing the coolant into a oil passage because the oil pressure dropped to zero when the engine was shut off.
