Cat D4D won't move
ScottP
06-30-2007 20:08:39
Does anyone have the repair manual for a powershift D4D? The neighbor took a wild ride on his, he went over the side of the mountain. He went about 500 yards down before he got it to stop. When he did stop the tractor was sitting at about 60 degrees nose down. It sat for a week before he could get back to get it out. He got it to semi level ground then got a boulder stuck between the rippers and the track.
After he got the boulder out it wouldn't move again.
I drained the transmission and checked the suction screen to make sure it wasn't plugged with sludge. The suction screen was clean. Refilled the tranny and took pressure readings on the tranny control valve.
The left port had 300 psi. the right port was at zero. What is the pressure supposed to be? Or any other ideas?
Thanks
Scott
ScottP
07-02-2007 08:03:29
 Re: Cat D4D won't move in reply to ScottP, 06-30-2007 20:08:39
Thanks for all the help.
I'll do some more checking.
Scott
Old Magnet
07-01-2007 14:03:53
Port pressures:
P1(speed clutch) - 305psi +/- 15psi
P2(directional clutch) - 50psi +/- 8psi below P2
P3(torque conv. inlet oil - 110psi +/- 10psi
Also torque conv. outlet oil 35psi +/- 5psi, located on TC housing near outlet line to oil cooler.
Old Magnet
07-01-2007 17:20:27
 Re: Cat D4D won't move in reply to Old Magnet, 07-01-2007 14:03:53
Forgot to mention. Both a speed clutch and a directional clutch must be engaged for power to be transmitted through transmission. Need to find reason for zero pressure at port #2. Check linkage adjustment first.
RENE'S
07-01-2007 13:26:33
I AM SORRY I AM SPEAKING OF THE STEERING CLUTCHS.O.D.FINGERS ON PLATES MOVE POWER TO THE GROUND.
AJK
07-01-2007 09:54:53
Sounds as it has sheared the splines from the coupling sleeve between the torque and transmission.
AJ
RENE'S
07-01-2007 07:11:30
CHECK TO SEE IF DRIVE SHAFT IS TURNING IF HE GOT ROUGH WITH IT GETTING IT OUT. THE TEETH ON THE O.D. OF THE DRY CLUTCHS MAY HAVE FAILED I HAVE SEEN THIS BEFORE.
ScottP
07-01-2007 08:55:45
 Re: Cat D4D won't move in reply to RENE'S, 07-01-2007 07:11:30
The only shaft I can see turning is the one between the fly wheel and the torque converter. Everything else is inside a gear box. I can pull the top off the transmission and see the clutch packs for it but they are wet with oil. Are you talking about the steering clutches?
We haven't got it out yet, it's still sitting in the bottom of the canyon. Scott
Bob/Ont
07-01-2007 04:36:42
About 250 in gear if it's marked P2.
Later Bob
ScottP
07-01-2007 09:03:27
 Re: Cat D4D won't move in reply to Bob/Ont, 07-01-2007 04:36:42
Bob
There are 4 plugs on the control valve. They are P1, P2, P3, and LUB. Only two of them can be accessed through the small covers on the main cover.
Do you know what the pressures are for these other ports. If I remember right P1 is where I had 300 psi. It would drop to zero in between gears. On the side for forward and reverse it stayed at zero.
Scott
