follow up-350 Case Adjuster
MLD
07-02-2007 11:59:30
I took the adjuster off, cleaned it up, took it apart. Only a snap ring & 2 seals, ordered a seal kit from Finney in AL. I put it back together, installed it on the machine, track came loose!! OK maybe just an air pocket, pumped it up, track came loose!!! Grease leaking out the back of the adjuster just like before. Took it back off & apart, flipped the seal over so the cup part was facing the cylinder & not the shaft, put it all back together. Track has stayed nice & tight, with no instructions I had to learn the hard way but its fixed!!!
