bolt rails for rollers D6B
U9 U9 CAT
07-02-2007 15:13:14
I need some bolt rails the ones that fit in the roller frames for the roller to bolt to Thanks D6B 44A CAT
Penn
07-04-2007 03:53:48
 Re: bolt rails for rollers D6B in reply to U9 U9 CAT, 07-02-2007 15:13:14
You probably tried your Cat dealer,if it is discontinued item take a sample of the old rail to your local machine shop and the should be able to make you up new rails,use antiseize on assembly and don't use bolts that are longer than needed,ie if the bolts sticks out a couple of threads through the rail they will rust and will not screw back out.
P
U9 U9 CAT
07-04-2007 23:05:49
 Re: bolt rails for rollers D6B in reply to Penn, 07-04-2007 03:53:48
good advise, I think I can make the old ones work, I was just venting, I had a long row to hoe, I got a lot of welding to do on the rollers
