#6 Cat Traxcavator question
Illinois Adam
07-04-2007 14:25:57
I recentlly bought a old 50's #6 Cat Traxcavator that runs and drives like a dream, but the hydrolics are getting a little weak.
It moves the bucket up and down fine when it is empty, but will not lift anything when the bucket is loaded. It has a Denison hydrolic pump on the front of it. Now my question. Does anyone know if you can rebuild them? If so who?
Does another type of pump fit this machine?
Thanks for looking
Adam Koch
Illinois Adam
07-05-2007 12:52:05
 Re: #6 Cat Traxcavator question in reply to Illinois Adam, 07-04-2007 14:25:57
Yeah, I checked, and changed the hydraulic fluids. I"m going to try a little heavier oil tonight (cross my fingers).
I looked in my manual also, and saw the same thing (about the two different pumps), but mine has the Denison. my serial # is 10A874.
I hope the oil works , but would really like to get it rebuilt.
Thanks for helping
Adam
Old Magnet
07-05-2007 13:10:05
 Re: #6 Cat Traxcavator question in reply to Illinois Adam, 07-05-2007 12:52:05
Are you sure the pump is the problem? Plenty of cylinder piston rod packings to leak. Did you do any testing the pump?
hectorgemme
07-05-2007 02:44:20
did you check the oil level in the tank and the hydrolique oil filter and this tractor use too a VICKERS pump and I check what am still have.
Old Magnet
07-04-2007 22:35:44
My 10A1 - 10A1616 Parts Manual shows there were two pumps available under the 6H2543 pump assembly part number. One by Vickers and one by Dennison. Can't help you with source for rebuilders. Try a google search.
