TD15C
oldsteel
07-04-2007 15:09:14
Purchased a td15c with a hole in the engine block not sure what the engine is but believe it to be a INT. Dt 466. The place where the casting# or serial# plate was is missing.Not been able to locate serial # tag for machine.Need to know this info for block replacement. The machine appears to be made in the early 70"s. Any info would be appreciated. thanks.
oldsteel
07-05-2007 20:27:06
 Re: TD15C in reply to oldsteel, 07-04-2007 15:09:14
The injection pump is on the left side of the block if you are sitting in the seat. Pump seems to be a rotary style. I will check location on block for serial # when I return to farm where machine sits. DWF I will give you a call about spare engine. Thanks everyone for the help.
DMont
07-05-2007 19:46:15
The TD15C was only produced with a DT466. The early versions had problems with the angle in which the rod cap mounted to the rod. This was later changed in the "B" version. The rod cap split angle was changed and the engine vastly imoproved. You can get a used block in the tractor wrecking yards. The same basic engine was used in farm equip., othe Const. equip. The farm version had a different injector pump head. It delivered less fuel. Make sure if you rebuild get the later version rods, and make sure to have new rod bolts. Have the injector pump spider washers check as they can slip and cause overspeeding of the engine which could have lead to the thrown rod.
Great tractor when bugs worked out.
DWF
07-05-2007 16:50:51
I have two TD15-C's. I am making one out of the two. The one that I will be parting has a running DT-466.
Call me if I can help. 218-365-3952.
DWF
Bob Blue
07-05-2007 08:04:22
As mentioned, left side of block , in center section , below where the head bolts on, Does it have an inline Bosch pump. Good engines, must not have been well maintained, or maybe it has never been rebuilt.
j.m. watkins
07-05-2007 04:59:57
If it is for shure a c model 15 it will have only one engine dt466 dead give away is which side of the engine is the injector pump mounted .
ALL IH 466 ENGINES HAVE A LEFT SIDE AS VIEW FROM THE REAR INJECTOR PUMP.. blocks, engines ect very cheap give me a call or tick e-mail for more infor
the tractor vet
07-04-2007 17:33:59
It could be anything from a DT 361 - DT407 or the DT 466 . A couple picture would be worthe a thousand words here . 466's are almost a dime a dozen but the others are not . Look along the top edges of the blocks for a machined surface as the engine size should be stamped on the side. Or mid way up on the block . Today i am a littel brain dead on exact location one to many sheets of drywall and three tomany barley pops.
