Case D750?
Evan MacDonald
01-03-2002 05:04:21
I recently came into posession of a Case D750 loader w/ripper, serial number 7070675. I need to get manuals for it. It was running, but my uncle took the injectors out so he could have 'em redone and hasn't found them in his garage yet. Apparently it has a very bad miss, but, I haven't heard it running. Also, my uncle managed to tip it up on it's right side, which broke some undercarriage pieces(I'll take some pics this weekend if I think of it.) But, other than that, it's only got 70 hours since it was re-built, so, it's in decent shape. This is my first diesel and crawler, so, I'll probably have ALOT more questions.... Evan MacDonald
Max
01-03-2002 21:04:24
 Re: Case D750? in reply to Evan MacDonald, 01-03-2002 05:04:21
Those misfires were normally cuased by using only one wrench to tighten the injector lines on the injection pump. There are copper gaskets under the fuel delivery connectors that crack when over torqued. Another item that will cause a misfire is a bad injector but it sounds like all the injectors are bad since there missing. Case offers excellant manuals but they are expensive but well worth the bucks in my opinion. Good luck.
