I H 500-C Motor problem, Timing?
Doug in pa
07-09-2007 05:52:40
I have an IH 500-C crawler that was running fine then started to miss, it slowly got worse until it died. I tried starting and even with either it does nothing. I have fuel at the injectors, but not even any white smoke. I'm figuring it has a timing problem and removed front cover, but I can't see how the crank gear is located on the crankshaft, also can't find any way to remove it. I don't see any problems there with gears and cam, all is intact. I'm guessing the gear might have moved on the crank, but I don't even see a key? Parts book does not show one either. I just bought a shop manual, but waiting for it to arrive. Has anyone had any experience with this, or have any suggestions. Thanks
