IHC T 340 crawler
HARRY DUNHAM
07-12-2007 02:46:50
need final drive bearings st 265, st 223a and oil seal.
pork
07-14-2007 14:27:49
 Re: IHC T 340 crawler in reply to HARRY DUNHAM, 07-12-2007 02:46:50
the numbers below from doug are correct, the seal # is national seal 5581.
CHinNY
07-14-2007 01:21:39
I have those bearings and seals in stock.
DougM
07-13-2007 14:37:58
Harry, From the Chicago Rawhide (CR) bearings master interchange catalog ST265 crosses to 6211-J, ST223A crosses to 214-J, hope this helps, If you have the IH # for the seal I can see if that crosses to a CR # in the seal catalog
HARRY DUNHAM
07-13-2007 20:59:27
 Re: IHC T 340 crawler in reply to DougM, 07-13-2007 14:37:58
Thank you Doug, I will sure give them a call monday.
the part number for the seal is 307 835 R 91
Thanks agin, Harry
DougM
07-13-2007 21:55:06
 Re: IHC T 340 crawler in reply to HARRY DUNHAM, 07-13-2007 20:59:27
Harry, that IHC # is not listed in the CR seal catalog, However they list an IHC # 307 8355 R1. This could be a miss print of your #, or a totally different part, can't say for sure, they cross that # to CR seal # 6610.
pork
07-12-2007 15:49:30
i think i have the fafnir part numbers you need, ill look tomorrow morning at the shop and let you know tomorrow night. i rebuilt an entire dozer a few years ago. i may have some other info if needed.
HARRY DUNHAM
07-13-2007 11:00:17
 Re: IHC T 340 crawler in reply to pork, 07-12-2007 15:49:30
I would realy appreciate it if you could come up with the numbers, I am at a loss as my old bearings are completly gone, as well as the housing is worn out. so am unable to get an exact size. Thanks Harry
