Hough Loader, carb, pedal, and hydraulic questions
DerekH
07-16-2007 04:17:12
I have a Hough loader and the carb is a single barrel Holley. I cannot see any "series" number on it, but I did get the possible serial number for it. It is 5P-394B or 5P-894B. Can anyone tell me what "series" it is so I can order a rebulid kit? Another thing the loader has 4 pedals; gas on the right, then just the Brake then a "clutch"/break pedal, then the 4th pedal what does it do? Oh yeh I have a lot of air in the hydraulinc lines how do I get it out? Thanks again guys.
450B-LUES
07-18-2007 10:28:33
 Re: Hough Loader, carb, pedal, and hydraulic questions in reply to DerekH, 07-16-2007 04:17:12
Any pin holes in the suction line will cause air to be drawn in.
Use an oil can to squirt oil on suspect spots while someone else holds the control valve on.You will be able to see the oil
being drawn in.Check the pump itself too.Just a thought.
