jd 450d trans oil cooler line
hig
07-16-2007 17:21:45
the dogon hose on the bottom of tranny oil cooler blows for the third time.can it get over pressured?
Roy Suomi
07-16-2007 18:35:45
 Re: jd 450d trans oil cooler line in reply to hig, 07-16-2007 17:21:45
There is a cooler relief valve built into the transmission case , under the top cover..Once you pull the trans top cover, clean the top of the case where the top cover contacts the case..You will notice a small flat plug in the top surface of the trans case in the front just behind the clutch housing..Pop this plug out and check for gunk in the valve..there's a spring in there too..Once it's all cleaned put it back in and tap that plug back in flush with the surface, Plastic Gasket the trans case top cover back down and try it...
hig
07-16-2007 17:54:50
thanks uncle. ill check that out.
uncle
07-16-2007 17:49:14
Mine did that too and the "EL" fitting that went into the trans was plugged up and would not take the flow.
It was a pain to get it out but it can be done.
Brian
