450C Case won't start hot
RookieBill
07-18-2007 21:20:16
Have been using a friend's Case 450C crawler ( mid 80"s I think) the past sereral months. With a new battery, starts immediately, even during colder weather. After it has gets to operating temperature, it won"t crank over until it cools down a couple of hours and will then be an easy start. I am considering buying this machine and would like to get this problem solved. Any ideas? I"m not much of a diesel mechanic. Thanks.
jdemaris
07-21-2007 18:23:51
 Re: 450C Case won't start hot in reply to RookieBill, 07-18-2007 21:20:16
Sounds like a common Stanadye injection pump problem. When the head & rotor assembly gets worn inside the pump, it will start fine cold - but not hot. Easy way to test it is . . . next time it's hot and won't start. Pour a bucket of cool water on the injection pump. Then crank it. If it fires right up after cooling the pump - you've got a bad head & rotor.
RookieBill
07-21-2007 21:20:44
 Re: 450C Case won't start hot in reply to jdemaris, 07-21-2007 18:23:51
Thanks for this tip; my guess is it pump problem. What is an estimate to have the injector pump rebuilt?
Thomas R. Spivak
07-19-2007 07:36:30
Won"t crank as in starter won"t spin motor or won"t fire up while cranking?
rookieBill
07-19-2007 17:41:57
 Re: 450C Case won't start hot in reply to Thomas R. Spivak, 07-19-2007 07:36:30
Starter spins it fine; just will not fire.
dads 320
07-20-2007 00:08:12
 Re: 450C Case won't start hot in reply to rookieBill, 07-19-2007 17:41:57
if staters bad have it checkeked out 2 check your oil presure and what kinda spark plug compression you got 3 possible coil could be faulty bad gas water in gass points could be faulty or to much gas in pistons keeping cylinders from moving needs possible valve job
RAB
07-20-2007 10:54:58
 Re: 450C Case won't start hot in reply to dads 320, 07-20-2007 00:08:12
I made same mistake recently. It is a diesel.
RAB
