Drott parts --where?
Charlie
07-20-2007 04:47:24
Can anyone direct me to a source of Drott parts? I’m looking for a small item, part S47549, a hardened steel bushing, 1-1/4 ID, 1-1/2 OD, length ¾. I thought Case still had these, but I understand Drott was sold again. This is from an old Drott Skidshovel scarifier on a TD340. Can't find a generic source for these bushings either.
Thanks for any help.
Charlie
NC Wayne
07-21-2007 19:59:20
 Re: Drott parts --where? in reply to Charlie, 07-20-2007 04:47:24
The 1 1/4 ID x1 1/2 OD ought to be a pretty common size but the 3/4 length might be hard to find. If you"ve already tried McMaster Carr, and MSC with no luck then give Connex a call, they should be able to help you out and make what you need. Can"t remember which one of the two or maybe both, but either MSC or McCarr carry the "Connex" style bushings because I"ve bought them before. Where ever you get them remember all you really need is the right ID and OD and to heck with the length. If you can find the right diameters but a longer bushing you can always use a cut off wheel and make it the right length either before or after putting it in. Good luck.
marlowe
07-21-2007 09:12:52
Drott made loaders for a lot of different co. massey,ih and many others if it on a Ih check them as for the co drott they are gone Case seen to that
AJK
07-20-2007 16:22:51
You may get a pointer over at the IH site at the link below,you have to register to post but its free.
AJ
