TD 340A
Yahhbutt
07-20-2007 06:42:07
I have recently aquired a IH TD 340A s/n 8898 with a Drott 4way attached.
I believe that this makes it vintage 1965. It"s been setting for over a decade and has 1584 hours on the dash meter. Any suggestions on approach to bringing this baby back to life. It was running when it was put up. Whole but rough around the edges. Any advise would be appreciated.
thanks- Barry
dej(jed)
07-23-2007 11:12:42
 Re: TD 340A in reply to Yahhbutt, 07-20-2007 06:42:07
I have a TD 340A and it is a great machine. If the motor isn't stuck and diesels usually don't stick, the big issue will be the fuel system.
Diesel gels and forms gums as it ages. The whole system will be full of bad fuel. You could flush the tank and lines and try starting, but the injectors and the pump could well be fouled out. It sure wouldn't hurt to try flushing the system before you do a start up.
Charlie
07-21-2007 15:28:57
I have essentially the same machine.I would begin by getting all the documentation that can be found, including the parts manual, the operators manual, and the manuals for each of the systems (engine, hydraulics, chassis, etc.). Copies of original IH manuals are definitely best. I would make sure the hydraulic filter and screen (lower right, opposite pump) are OK so the pump gets enough clean fluid right from the start.
pork
07-21-2007 12:00:48
it took me ten years off and on and about 7500 bucks to fully restore a t-340 dozer. these are sweet machines to operate and work on. e-mail me if you need info about anything.
yahhbutt
07-20-2007 10:34:37
Milton, Thanks for the information. Lucky as I am I also recieved complete parts & maintenance manuals for the crawler and all it's pieces including the drott. Time to get at making this thing run before the NH summer runs out.
Thanks again,
Barry
Milton
07-20-2007 10:28:56
Barry, --- 20 / July / 2007 ---
Your IH "TD-340A" Serial Number "8898" was made
in 1965 and was the last year that they were
made, and were made in US. . They were the counter-part to the T-4, T-5, TD-5, and 500 crawlers made in Canada.
The T-340A(and TD-340A) was made from 1959 to 1965. Parts Catalog is TC-77C.
Milton
Milton
07-20-2007 10:28:50
Milton
