AC HD-5G 2-71 spitting fire.
Dozerguy
07-24-2007 17:28:02
My HD-5G's GM 2-71 is acting like it's flooding itself and when it recovers, it is spitting flames out the stack. Any suggestions as to why this might be happening? Timing? Governor?
Thanks.
dozerguy
07-25-2007 17:29:04
 Re: AC HD-5G 2-71 spitting fire. in reply to Dozerguy, 07-24-2007 17:28:02
I found the fan belt on the HD-5G had loosened and the water pump obviously wasn't moving enough water. Also determined that the temperature gauge is faulty. Running fine now.
Bob Blue.
07-24-2007 19:10:16
With fuel off, does it spin thru with about the same compression on both cylinders, or does it pick up on one and slow on the other. thinking about a stuck exhaust valve. What is the exhaust color, black with fire, white with fire,. I am leaning towards one cylidiner dead and the raw fuel from it igniting in the stack as it blown out of the exhaust valve by the blower on downstroke. I had a valve break once and it was pushed back into the seat side ways and stayed there. Limped back on one jug, a lot of wihite smoke but no fire. Was it running perfect before and happen during operation? bob
