JD450C rollers
Mark / ca
07-25-2007 07:48:12
Hi,
Question on lower rollers - I am attempting to check the oil in the lower rollers and most of the 1/8" allen plugs are stripped. It should use a 3/16 allen, but like I mentioned they are stripped. Any ideas as to how to get them out? Easy out? Weld a nut on? Thanks..
Roy Suomi
07-25-2007 14:37:28
 Re: JD450C rollers in reply to Mark / ca, 07-25-2007 07:48:12
Drill 'em and easy-out them..Or drill 'em and tap them for a set screw with sealer on the threads..Some wouldn't come out when new..Part of the new machine service....
Don K.
07-25-2007 09:34:03
I used an easy out when I removed the plugs on mine. Use some never seize when you put in the new plugs if you are planning on keeping the dozer for a while.
