Case 1150B
Pat Wilson
07-26-2007 11:39:04
I have a 1150B dozer w/ a transimission leak. The leak is coming from a gasket or shim between the transimission and maybe a brake housing on the front of the transmission, under the your right foot as your seated. There is also the same thing under the left foot but the it's not leaking.
Is this an easy task, to take off the housing and replace the gasket or shim?
Wilson
ben brown
07-26-2007 13:33:59
 Re: Case 1150B in reply to Pat Wilson, 07-26-2007 11:39:04
if i thinking rt that would be the brake housing there is a seal when a short shaft come out and in to the brake disk. can be done not all that easy but posiable lot on you head up side down. but it can be done.
