points setting
dan-o
07-27-2007 18:52:19
what is points gap setting on pony motor for a
d6 9u cat. what is rotor setting, how to set gap
thanks for help dan-o
hector gemme
07-28-2007 08:59:17
 Re: points setting in reply to dan-o, 07-27-2007 18:52:19
the point gap is betwing .014 to .018 inch.
dan-o
07-28-2007 11:37:23
 Re: points setting in reply to hector gemme, 07-28-2007 08:59:17
what plugs do you suggest using in pony motor and what gap setting thanks dan-o
Old Magnet
07-28-2007 11:54:33
 Re: points setting in reply to dan-o, 07-28-2007 11:37:23
NGK A-6 @ .025 (18mm)
dan-o
10-09-2007 19:14:39
 Re: magneto info. in reply to Old Magnet, 07-28-2007 11:54:33
magneto has been taken out and reinstalled several times, if it is 180 out, do you remove
magneto and roll motor one half turn and reinstall magneto, is this the correct procedure
also there is only one wire coming off the magneto,there is no power going to the magneto
is this correct,there is 12 volt's at coil on top of starter, spark is very weak, and can't
get pony motor running, to check out main motor,
thanks for any information,and any checking procedure's or advice would be appreciated
dan-o
07-30-2007 16:31:11
 Re: points setting in reply to Old Magnet, 07-28-2007 11:54:33
DID GET SPARK TO PLUGS,IT WAS THE ROTOR ADJUSTMENT,ONLY TO FIND NO COMPREESION ON
ONE OF THE CYLINDERS,PUT THUMB OVER ONE HOLE
AND IT BLOWS YOUR FINGER OFF,OTHER SIDE DOES NOTHING,THIS IS A D6 REBUILT PONY AND DIESEL,
WHOLE SHOW, FROM A COMPANY IN PHILLY, I'M IN
ALASKA,SUPPOST TO BE ENTIRELY REBUILT PONY AND
DIESEL,PISTONS, RINGS ,EVERYTHING,KNOW I'M NOT SURE HOW THIS WILL WORK OUT FOR ME CAUSE
PONY IS BAD, GONNA USE OLD PONY AND HOPE FOR
BEST,WILL KEEP ON POSTING UPDATES...THANKS
Old Magnet
07-30-2007 20:48:53
 Re: points setting in reply to dan-o, 07-30-2007 16:31:11
That's a tough break....suspect you probably have a stuck valve.....that's about all that would do that unless something is seriously broke. Pull the cylinder head off the bad side and see what gives.
You can reuse the head gasket if it doesn't get tore up.
dan-o
07-31-2007 00:57:02
 Re: changing d6 pony motor in reply to Old Magnet, 07-30-2007 20:48:53
any info or tips that can be shared on changing pony motor out of 1958 d6 9u from any one would be appreciated ,already loosened old motor and it came loose and fluid went everywhere, made
my mech. wonder, because he is not real fimilar
with this old stuff...thanks for any help dan-o
Old Magnet
07-31-2007 07:22:44
 Re: changing d6 pony motor in reply to dan-o, 07-31-2007 00:57:02
That's about the only surprise....otherwise it's a pretty straight forward job. Be sure to vent the air from the new installation when filling the cooling system. Did you look any further into the problem with the new one?
dan-0
07-31-2007 10:07:49
 Re: changing d6 pony motor in reply to Old Magnet, 07-31-2007 07:22:44
did not look any further into new pony,just removed bolts holding down pony, oil and antifreeze came running out, is the oil and antifreeze mixture
a surprise, just shook motor loose and started looking at how were gonna pick it, we have no
equipment handy,so we gotta try and figure that out,hopefully these motors are interchangeable
both are from d6 motors, so i hope so,will pull cover later
and let you know what i find,will call philly
today to express my concerns,we paid 10,000 for
motor plus about 2000 shipping to alaska,never
know if your making the right choice,we will see thanks for help dan-o
Old Magnet
07-31-2007 10:43:18
 Re: changing d6 pony motor in reply to dan-0, 07-31-2007 10:07:49
What I meant is the "flood" was a surprise to you.
Both the cooling system and the pony oil sump separate at the the bellhousing. All the D6 horizontal twin pony motors interchange. Same block but there may be variations in the bolt on goodies. I think I would have investigated the new pony further before pulling but understand you may want to work out warranty issues. It would be fairly easy to have a valve stick if the new clearances were tight, there was inadequate assembly lube and/or ample time and moisture to cause a problem plus inadequate shipping/storage precautions. Would be curious to see what you find.
Before you land the old pony, check stud sizes/holes in the bellhousing. It's not to uncommon to find oversize replacements if there was a thread problem.
dan-o
07-28-2007 11:59:16
thanks for info on plugs, going to cabin to work on dozer today thanks for input...dan-o
Old Magnet
07-28-2007 08:54:02
Info is on its way.
Old Magnet
07-27-2007 20:22:17
Give me an email address either through here or your ACMOC post and I'll send you the timing info.
