Weight of TD14
Smileykeith
07-28-2007 20:01:34
What does a TD14 with 11 ft angle blade with cable lift and double spool winches Thanks
DougM
07-28-2007 21:51:33
 Re: Weight of TD14 in reply to Smileykeith, 07-28-2007 20:01:34
Keith,the spec sheets I have on the early 14A says the Service weight of the bare crawler, ie: no attachments is 16000lbs for a standard tread & 16850 lbs for the wide tread. I don't have any specs on the cable blade assemblies of that era, but the Hydraulic Isaacson blade for that machine wieghed 6090 lbs for standard tread & 6383 lbs for wide tread. I would guess at least another 2000 lbs for the difference between cable operated & the hydraulic. that would put your machine as fitted at a minimum of 25200 lbs. Just for comparison the spec for a 1956 TD-14 141 series with Drott loader shows 30975 lbs. Sorry I can't get you any closer, hope this helps somewhat.
