JD 350 Questions
uncle
07-30-2007 19:35:59
I need the spec for the fibers and steels in a straight 350 JD Trackloader.
I noticed that when I back up and apply the left steering/brake, the machine stops completely and the engine bogs. You can pull forward a couple inches and it releases.
Any Ideas on this?
Thanks, Brian
dlplost
07-31-2007 09:54:51
 Re: JD 350 Questions in reply to uncle, 07-30-2007 19:35:59
sounds like your just out of adjustment.
jdemaris
07-31-2007 06:05:28
It originally used 8 fiber disks and 7 steel disks on each side.
When all is working - and adjusted correctly - you can pull back the lever to a certain point where the steering clutch is fully disengaged - but the steering brake is not grabbing yet. If the brake grabs too soon - the engine will labor.
