Cat D6 steering clutches
Steve Frischkne
07-31-2007 11:57:06
I have a d6 SN 9U21218. The left steering clutch is not disengaging. It feels good and you can see the clutch moving in and out but it will not turn. The brake will stop the crawler. What is the best way to dissassemble and get at the clutch disc. Any other advice?
Bob Plumadore
07-31-2007 15:56:07
 Re: Cat D6 steering clutches in reply to Steve Frischknecht, 07-31-2007 11:57:06
I will E mail you instruction on adjusting, removing and reinstalling the S.C. Please dont try to dissamble with out the roper tooling
Old Magnet
07-31-2007 13:21:11
Did you try adjusting the steering clutch linkage??
Steve Frischknecht
07-31-2007 16:39:58
 Re: Cat D6 steering clutches in reply to Old Magnet, 07-31-2007 13:21:11
I have adjusted the brakes and the linkage on the steering clutches to no avail. The steering clutch in question is not as smooth as the other but does move in and out
Bob/Ont
07-31-2007 12:50:14
Take off fuel tank and clutch cover. There is a ring of bolts in the drum and a ring in the inner stubshaft flange. Likely release bearing has come apart.
Later Bob
Steve Frischknecht
07-31-2007 12:59:20
 Re: Cat D6 steering clutches in reply to Bob/Ont, 07-31-2007 12:50:14
Thanks for the quick reply. I will try that first
Steve
