544G
SteveGR
07-31-2007 14:04:12
I have a friend who has a 544G that will not shift into 3rd and 4th. I checked the screen and filter for metal and found none. The torque convertor does not over heat. The oil is nice and clear with no burnt smell. Since this is an electric shift ZF trans. would a shift solenoid do this, when you shift past second it just stays in second. Any ideas would be helpful.
720 in pa
08-01-2007 08:55:50
 Re: 544G in reply to SteveGR, 07-31-2007 14:04:12
what jonathon said.also if you change the speed sensor make sure you put all the shims that were on the old one back on the new one.99 percent chance thats whats wrong with it.
Jonathan in MA
08-01-2007 04:24:38
If the speed sensor decides to give up it will revert to a "safe-mode" so to speak and not shift above 2nd speed...part number is AT184944... should be on the lower right side of the transmission case..check the wiring to it also.... maybe something yanked it off of the sender..
