Still can't find the rare nut
Case450
08-02-2007 12:06:12
third party image
I do however have a very good mechanic on the prowl for me....he said it shouldnt be a problem finding what I need...I just wish he'd hurry up...snow will be flying before ya know it!!
John-Paul
08-20-2007 12:25:32
 Re: Still can't find the rare nut in reply to Case450, 08-02-2007 12:06:12
Like said earlier. You only need two measurements. The outside diameter, and the thread count (pitch). Mark off one inch on the bolt. Count the number of threads in that 1 inch distance. Now use a micrometer (a older style is $10) and take the outside diameter measurement. Now armed with those two vital specs you WILL find a nut that fits I assure you. Just make SURE its a high grade nut like grade 8 if its for a wheel or spindle (Im guessing by photo heh).
Skyhawk Greg
08-05-2007 18:46:03
Measure the OD of the thread, and figure out how many threads per inch. Then call D&W Fasteners in Barberton, Ohio. They have always been able to locate what I need.
AJK
08-02-2007 16:04:19
Take the nut off the other side and go to a machine shop and have them make you a couple of nuts.
AJ
Chuck Bergstrom
08-02-2007 14:51:59
My parts book shows two nuts p/n 1029537m1
with a lock between them p/n 1029529m1. MinnPar
in Mpls, Mn. has had them in the past. Call them
at 612-379-0606. We used to find parts for the
axle set ups on Washington Ave in Mpls but that
stuff is now gone. They were the same unit as
some older army trucks. Good luck, Chuck
